Orbiting Around an Object
Home Forums Graphics / Blender Orbiting Around an Object
  • #26844
    cristianctin
    Hello,
    Is there any solution for orbiting the camera around an object but keeping the HDRI in a fixed position.
    For reference please see this link.
    https://www.meisterschmuck.ch/shop/en/engagement-rings/Engagement-Ring-31-2-7-mm-0101-0000-0000-1-Brill-0-45-ct-G-VS-53-mm.html
    There it seems that the object it is rotating but the environment it is fixed in its fix position.
    Thank you in advance for any suggestion to achieve this .
    #26845
    To change orbiting for a camera use Look at puzzle for new position of the orbiting. Environment always stay on it’s position.
    #26853
    cristianctin
    Hello,
    When I use Look, the animation plays and the Environment stays on position.
    However I need the Environment to stay in its position when I rotate the model with the mouse in Browser.
    Is it possible ?
    Thank you
    #26855
    cristianctin
    Sorry for the error.
    When animation is playing the Environment it does not stay fix, but it follows the rotation of the model.
    Thank you
    #26862
    This was made using matcap in material for metalls.
    #26932
    cristianctin
    Thank you for sharing this solution.
    It is very useful.
    Thank you
    #26933
    :good:
