Home › Forums › Programming › orbit camera collision / limits (feature request?)
- This topic has 8 replies, 5 voices, and was last updated 3 years, 8 months ago by
AVerge3Der.
2020-11-20 at 2:22 pm #35565
thomasup
Customernot sure if this feature exists, but we would like to keep the orbit camera from moving inside of objects.
so it would be a helpful feature to give it a collision material, similar to the first person camera.
an alternative would be using the Min / Max Angles, but since they are not visible in the viewport, it is hard to set them up correctly. a viewport gizmo/overlay/handles would be appreciated here.
2020-11-20 at 3:45 pm #35576thomasup
Customermade a short script, that shows the limits:
it adds a button to the UI: currently it is creating a mesh, with the near and far limits & angle limits.
downside: you have to undo / delete it & click the button again, every time you change a limit value.
upside: you dont have to export to find outmaybe this can be fleshed out & integrated into v3d natively
# Author: Thomas Pahler @ UP Designstudio import bpy, bmesh, mathutils, math def draw(): camera = bpy.context.active_object obj = bpy.context.scene.objects.get("debugCube") if not obj: mesh = bpy.data.meshes.new("debugCube") obj = bpy.data.objects.new(mesh.name, mesh) scene = bpy.context.scene scene.collection.objects.link(obj) else: mesh = obj.data verts = [] edges = [] faces = [] # get camera limits tgt = camera.data.v3d.orbit_target pos = camera.location camDirection = pos-tgt near = camDirection.normalized()*camera.data.v3d.orbit_min_distance+tgt far = camDirection.normalized()*camera.data.v3d.orbit_max_distance+tgt # add cross at target position def drawCross (position): verts.append(position-mathutils.Vector((0,1,0))) verts.append(position+mathutils.Vector((0,1,0))) verts.append(position-mathutils.Vector((1,0,0))) verts.append(position+mathutils.Vector((1,0,0))) verts.append(position-mathutils.Vector((0,0,0))) verts.append(position+mathutils.Vector((0,0,1))) drawCross(tgt) #add line from near to far, in camera direction verts.append(near) verts.append(far) #add circles count = 32 #add circle for horizontal limits at near limit distance angle = camera.data.v3d.orbit_min_azimuth_angle endAngle = camera.data.v3d.orbit_max_azimuth_angle sweepAngle = endAngle-angle for i in range(count): angle += sweepAngle/count verts.append(mathutils.Vector((math.sin(angle),-math.cos(angle),0)) *camera.data.v3d.orbit_min_distance + tgt) #add circle for vertical limits at far limit distance angle = camera.data.v3d.orbit_min_polar_angle endAngle = camera.data.v3d.orbit_max_polar_angle sweepAngle = endAngle-angle for i in range(count): angle += sweepAngle/count verts.append(mathutils.Vector((0,-math.sin(angle),math.cos(angle))) *camera.data.v3d.orbit_max_distance + tgt) # make edges for i in range(int(len(verts)/2)): edges.append([i*2,i*2+1]) mesh.from_pydata(verts, edges, faces) #def emptyAtPosition (name, position, direction): # obj = bpy.context.scene.objects.get(name) # o = bpy.data.objects.new( "empty", None ) class DrawCameraLimits(bpy.types.Operator): bl_idname = "v3d.draw_camera_limits" bl_label = "Draw Limits" bl_options = {"REGISTER", "UNDO"} def execute(self, context): draw() return {'FINISHED'} def menu_func(self, context): self.layout.operator(DrawCameraLimits.bl_idname) bpy.utils.register_class(DrawCameraLimits) bpy.types.V3D_PT_CameraSettings.append(menu_func) #bpy.ops.v3d.draw_camera_limits()
2020-12-09 at 4:39 pm #36311thomasup
Customerwe made an extension script, which draws the limits as a mesh.
it is very hacky as of now, but helps iterate faster on the limits.a nicer implementation as overlay / tool / handle would be nice, but not sure how this is possible in blender 2.8+.
import bpy, bmesh, mathutils, math def draw(): camera = bpy.context.active_object obj = bpy.context.scene.objects.get("debugCube") if not obj: mesh = bpy.data.meshes.new("debugCube") obj = bpy.data.objects.new(mesh.name, mesh) scene = bpy.context.scene scene.collection.objects.link(obj) else: mesh = obj.data verts = [] edges = [] faces = [] # get camera limits tgt = camera.data.v3d.orbit_target pos = camera.location camDirection = pos-tgt near = camDirection.normalized()*camera.data.v3d.orbit_min_distance+tgt far = camDirection.normalized()*camera.data.v3d.orbit_max_distance+tgt # add cross at target position def drawCross (position): verts.append(position-mathutils.Vector((0,1,0))) verts.append(position+mathutils.Vector((0,1,0))) verts.append(position-mathutils.Vector((1,0,0))) verts.append(position+mathutils.Vector((1,0,0))) verts.append(position-mathutils.Vector((0,0,0))) verts.append(position+mathutils.Vector((0,0,1))) drawCross(tgt) #add line from near to far, in camera direction verts.append(near) verts.append(far) #add circles count = 32 #add circle for horizontal limits at near limit distance angle = camera.data.v3d.orbit_min_azimuth_angle endAngle = camera.data.v3d.orbit_max_azimuth_angle sweepAngle = endAngle-angle for i in range(count): angle += sweepAngle/count verts.append(mathutils.Vector((math.sin(angle),-math.cos(angle),0)) *camera.data.v3d.orbit_min_distance + tgt) #add circle for vertical limits at far limit distance angle = camera.data.v3d.orbit_min_polar_angle endAngle = camera.data.v3d.orbit_max_polar_angle sweepAngle = endAngle-angle for i in range(count): angle += sweepAngle/count verts.append(mathutils.Vector((0,-math.sin(angle),math.cos(angle))) *camera.data.v3d.orbit_max_distance + tgt) for i in range(int(len(verts)/2)): edges.append([i*2,i*2+1]) mesh.from_pydata(verts, edges, faces) #def emptyAtPosition (name, position, direction): # obj = bpy.context.scene.objects.get(name) # o = bpy.data.objects.new( "empty", None ) class DrawCameraLimits(bpy.types.Operator): """draw the camera limits as a 3d object""" bl_idname = "object.draw_limits" bl_label = "draw limits" bl_options = {'REGISTER', 'UNDO'} def execute(self, context): draw() return {'FINISHED'} def menu_func(self, context): layout = self.layout print("test") layout.separator() layout.operator(DrawCameraLimits.bl_idname) classes=[ DrawCameraLimits ] def register(): for c in classes: bpy.utils.register_class(c) bpy.types.V3D_PT_CameraSettings.append(menu_func) def unregister(): for c in classes: bpy.utils.unregister_class(c) bpy.types.V3D_PT_CameraSettings.remove(menu_func) if __name__ == "__main__": register()
You must be logged in to view attached files.2020-12-10 at 9:53 am #36353Yuri Kovelenov
Staff2021-04-21 at 3:52 pm #40372thomasup
Customersince we use these limits quite a lot, i had a deeper look at it, and updated it to use gizmos.
they are not perfect (some range visual instead of two circles would be nicer), but they help a lot speeding up the worflow to set up and change limits.we packed it as an installable plugin, so others can use it easily: download the .py and install via the blender preferences.
feel free to integrate this one in a future verge3d release, if wanted.
You must be logged in to view attached files.2021-04-21 at 3:53 pm #40374thomasup
Customersecond try to add the package, maybe a zip works?
2021-04-22 at 11:31 am #40413dsimon_aas
Customerthat will be super helpful, until now what ive been doing is locking camera to view locking camera on target then setting distance constraints + angle which gives you a locked in range that you can fly around and test out and adjust but seeing will be nice
2021-05-16 at 11:31 am #41051visualizer
CustomerHi
Thomasupthat’s really a cool suggestion. This is something missing from verge as of now but will be cool addition for speeding up the work.
It will bypass adjusting parameters and checking them by publishing and again readjusting & then finalize.
2021-07-31 at 2:56 pm #43347AVerge3Der
Participantsecond try to add the package, maybe a zip works?
Thanks for sharing Thomas. A short video clip showing and telling how to use this add-on would be helpful.
Again, thanks for sharing.
