Home › Forums › WebGL & WebXR Troubleshooting › Orbit cam autorotate webGL error and textures missing on iphone X
- This topic has 19 replies, 5 voices, and was last updated 4 years, 9 months ago by
GLiFTeK.
2020-02-20 at 3:10 pm #23772
samuraijkm
CustomerHi Devs,
I’ve been updating my verge app with new features and there is a weird bug that was introduced where the textures don’t load on iphone X. My co-worker has iphone 11 and it works fine on his, but my phone turns every object black. I get no texture limit errors and it was working before just fine.
I’ve also got a an auto rotate camera error, I can’t get rid of. The camera switches from orbit to flying camera when clicking the expand button. I switch the auto rotate off before the camera switches but I’m still getting the webGL error, which starts iterating until you exit that view and go back to the orbit camera.
Lastly, I am still getting a v3d. property binding: animated node error on the expansion icon I just added to the app even though the other animated node errors before are fixed via the latest prerelease update of verge3d.
Here is a link to my web page with the app – O2i verge app
Any advice would be appreciated.
Sincerely,
Jason2020-02-20 at 3:16 pm #23773samuraijkm
CustomerHere is a screen shot of the webGL errors for reference…
2020-02-21 at 3:58 pm #23824Ivan Lyubovnikov
StaffHi samuraijkm,
Unfortunately, we couldn’t reproduce this error so far. It can be possibly related to webgl texture limits. It would be helpful if you show us the webgl system report for that particular device by opening the following page https://www.soft8soft.com/webglreport/
I guess the cause of the issue is that the application automatically reenables autorotation after a while. I found that this is programmed in the reset_auto_rotation() procedure by creating a timer “myTimer”. So, the solution here is to disable that timer as well when you need turn off autorotation. You can do that by using the
“remove timer” puzzle (https://www.soft8soft.com/docs/manual/en/puzzles/Time.html#remove_timer).Lastly, I am still getting a v3d. property binding: animated node error on the expansion icon I just added to the app even though the other animated node errors before are fixed via the latest prerelease update of verge3d.
This is actually was bug in the engine itself and fixed it just now. So, thanks for bug reporting! The error should be gone in the upcoming verge3d preview/release update. I think you can just ignore it by now, since it shouldn’t break any existing animation.
2020-02-21 at 8:56 pm #23834Branden Coker
CustomerRegarding the black model/missing environment: I’m able to reproduce it here on a second device. This one is an older iPad Air model MD787LL. Looking at this page:
https://www.ifm.com/us/en/us/learn-more/temperature/tcc/tcc
I get this result:
There are no lights in this scene. The results look to me as though the environment image is not loading. The scene linked here only has a total of three textures. I’m attaching a screen grab of my WebGL report here as well.
2020-02-21 at 9:01 pm #23837Branden Coker
CustomerWell, I just posted an edited response to this, but I guess I got flagged as pending review.
2020-02-24 at 4:49 am #23851Yuri Kovelenov
Staff2020-02-25 at 1:46 pm #23879Yuri Kovelenov
Staff2020-02-25 at 1:58 pm #23882Branden Coker
CustomerSounds good, thanks Yuri!
2020-02-29 at 12:41 pm #24049Yuri Kovelenov
Staff2020-03-02 at 4:56 pm #24121Branden Coker
CustomerHi Yuri, I’m having some strange issues with this application. When I attempted to update the app with pre3, I got the usual dialog to choose which documents should be updated. After clicking OK nothing appeared to be updated (same file modified dates).
I then attempted to re-export the gLTF files, but I got a series of errors from Blender (2.82), and no file was written. Later I tried to update the files again in the application manager and I got an error stating “Missing app update information.”
I’ve been using 2.82 and pre3 for most of last week on other projects, and everything seemed to be working fine.
Here are the errors that Blender returned:
V3D-WARNING: Object "incoming data" has a non-identity parent inverse matrix. Creating proxy nodes. V3D-WARNING: Object "outgoing data" has a non-identity parent inverse matrix. Creating proxy nodes. Traceback (most recent call last): File "C:\Users\uscokebr\AppData\Roaming\Blender Foundation\Blender\2.82\scripts\addons\verge3d\__init__.py", line 140, in execute return gltf2_export.save(self, context, exportSettings) File "C:\Users\uscokebr\AppData\Roaming\Blender Foundation\Blender\2.82\scripts\addons\verge3d\gltf2_export.py", line 134, in save sort_keys=True, ensure_ascii=False) File "C:\Program Files\Blender Foundation\Blender 2.82\2.82\python\lib\json\__init__.py", line 238, in dumps **kw).encode(obj) File "C:\Program Files\Blender Foundation\Blender 2.82\2.82\python\lib\json\encoder.py", line 199, in encode chunks = self.iterencode(o, _one_shot=True) File "C:\Program Files\Blender Foundation\Blender 2.82\2.82\python\lib\json\encoder.py", line 257, in iterencode return _iterencode(o, 0) File "C:\Program Files\Blender Foundation\Blender 2.82\2.82\python\lib\json\encoder.py", line 179, in default raise TypeError(f'Object of type {o.__class__.__name__} ' TypeError: Object of type Object is not JSON serializable location: <unknown location>:-1 location: <unknown location>:-1
Update: I was able to get rid of the two warnings in lines 1 and 2. I just changed the parenting of those items (deleted two empties). The other errors remain.
2020-03-02 at 9:31 pm #24130Branden Coker
CustomerAnother update: I was able to update the Verge application by creating a new application and replacing the models with the relevant files.
The problem is now I’m getting a ton of node errors that all say to reexport the scene. Which takes us back to the problem I posted earlier; can’t export the scene currently from 2.82 using pre3.
The good news is that all of the shaders are now appearing in older versions of iOS.
http://localhost:8668/applications/TCC%20rev-2/hippo_test.html
2020-03-03 at 7:25 am #24158Yuri Kovelenov
Staff2020-03-04 at 6:35 am #24228Branden Coker
Customer3.0.0pre3 does appear to fix the black model problem we were experiencing on older iOS versions. We’ve now tested this page successfully after updating it to pre3:
We’re working on updating our other app now.
As for the export errors I mentioned, this seems to be related to the texture input node when selecting an object as the input. I posted details on that issue here:
2020-03-04 at 6:36 am #24233Yuri Kovelenov
StaffWe’ve now tested this page successfully after updating it to pre3
excellent!
Fixed that one!
2020-03-04 at 9:48 pm #24305samuraijkm
CustomerYuri and Ivan,
Thanks for working on these bugs and being so responsive in development. As Branden had said, we were able to fix our texture issues and the removing the timer worked great for me as well. I can report that my verge app is now bug free and working on the iphone X!
You guys rock!
