opentype.js – not copying to application folder during when “Updating”
Home Forums Bug Reports and Feature Requests opentype.js – not copying to application folder during when “Updating”
  • #38297
    Hi there,
    I recently updated to version 3.6. I copied a project form my 3.5 folder to my new 3.6 verge folder…and after doing so…you get a “Update” icon to update your application to 3.6.
    After update the application runs fine but has an error that OpenType.js was missing. This can be found in the browser Console Window.
    To resolve the issue I had to copy the OpenType.js file in from the build folder to the root of my application and all is well.
    Just thought this should be copied over during the “update” process.
    #38319
    Since your app had no opentype.js module before, the updater can’t resolve that it will be required. Thus, you need to copy your module manually. This situation is similar to missing Physics or IE compatibility modules.
    Perhaps we might need to add some “override” option to the installer to force copying the modules.
    X | FB | LinkedIn
