object rotation degrees vs number of object rotations
Home Forums General Questions object rotation degrees vs number of object rotations
  • #70214
    I am hoping someone other there has already solved this problem.
    I have a cylinder I need to rotate. I need to calculate the number of total degrees the cylinder has rotated. As an example if the cylinder rotates 2 complete turns I need a value of 720 if it rotates in the opposite direction 2 complete turns I need a value of -720.
    Currently it seems the only values I can get from the get object rotation is : World Space 0 to 90 and then -90 to 0… and in local space I can only get values 0 to 180 and -180 to 0.
    I am hoping someone has worked out some logic or a method to calculate the total rotation?
    Given the cylinder can be rotated in either the postive or negative direction and will be controlled by a user so they may go back and forth quite a bit.
    Any help would be greatly appreciated.
    #70278
    Hi xeon,
    Unfortunately the current way how the drag rotate puzzle works does not allow the user to capture the total amount of rotation. In fact it’s a fundamental limitation of how rotations are handled in Verge3D. We are using quaternions which do not preserve the information about previous rotation value. :-(
