Object puzzles – differentiate between vertex groups?
Home › Forums › Puzzles › Object puzzles – differentiate between vertex groups?
Viewing 15 posts - 1 through 15 (of 26 total)
  • #75962
    c4cc
    Example:
    o46x1
    If I want the top 2 segments to rotate like a rubic cube, how to get object puzzles to rotate the selected vertex groups?
    #75968
    puzzles won’t allow you to manipulate vertex groups directly. use bones.
    Segments 2 and 3 share the same 4 vertices. You can’t rotate segment 2 without distorting segment 3.
    #75969
    c4cc
    Thanks. Also, if a blender file has more than one animation, how do I get animation puzzles to select a certain animation?
    #75970
    More than one animation per object? It’s not supported in Verge3D.
    #75974
    c4cc
    I see, I was gonna produce a web/browser game where the playable character can do multiple actions but I guess I gotta create separate blend files for each of its various actions then.
    This is one reason why I asked if hiding objects would improve overall user performance, esp for memory and fps
    #75976
    Nope. You can create one animation containing all required sub-animations and play them from frame to frame when needed.
    Instead of playing from frame to frame you can cut one animation into several parts and play them individually.
    #75977
    c4cc
    Thanks, this is actually a good answer. I’ll try this for sure B-)
    #76615
    c4cc
    Late reply, I noticed here you cloned an animation clip to play from frame to frame. Why can’t we simply play frame to frame, using “Play animation puzzles”? Or using “Get animation of”? Or even “Select an animation clip”?
    Is there a difference between these 4 ways of playing from frame to frame?
    #76621
    c4cc
    I’m trying to play animation from frame to frame when keys are pressed, yet it doesn’t work
    #76854
    c4cc
    Why are we only limited to this, and not as I mentioned below:
    #76983
    c4cc
    Why do we have to clone parts of animation to play those parts, and not simply play part of the original clip when needed?
    #77034
    c4cc
    Also, why can’t I play an animation in reverse? I can play a cut clip:
    o46x1
    But in reverse, it doesn’t work:
    o46x1
    #77037
    look at your puzzles with more attention and remove unneeded puzzles.
    #77038
    c4cc
    Done, still not working :unsure:
    I’m trying to freeze an animation after it plays for 2 seconds, then play it in reverse
    #77050
    You can’t play the legs animation from 31 to 39. After cloning it has only 9 frames, from 0 to 8. The same with other animations. They are short.
