Home › Forums › Bug Reports and Feature Requests › Object output for Texture Coordinate node
- This topic has 14 replies, 5 voices, and was last updated 5 years, 4 months ago by
Branden Coker.
2019-12-20 at 3:49 pm #22200
Branden Coker
CustomerAre there any plans to support the object output node (and object selection) for the Texture Coordinate node? This would be a useful addition for controlling textures. I know it’s currently possible to animate a value and move a texture, but there is currently no way to fix a texture position while moving the object as seen here:
2019-12-20 at 4:14 pm #22205Anonymous
Inactiveyou could also try Texture Coordinate > Object mode like this:
2019-12-20 at 4:24 pm #22207Branden Coker
CustomerHi Abin, I just tried your suggestion, but the gradient still moves with the object when I do that.
2019-12-23 at 7:05 am #22236Yuri Kovelenov
Staff2019-12-27 at 8:43 pm #22437GLiFTeK
CustomerHi Branden,
We have added a task to our dev tracker to make the Object field of Texture Image node work. Do you also need the Window output of the Geometry node as you mentioned here?The OBJECT and WINDOW components would be SO, SO very useful.
Branden and I are talking about the same exact desired effect.
Thanks for all your work.
plz share Discord link & on your signature!2020-01-06 at 2:01 pm #22601Branden Coker
CustomerHello Yuri, Happy New Year! First day back at work here. Window output would also be great. Thank you for your fast response.
Cheers,
BrandenHi Branden,
We have added a task to our dev tracker to make the Object field of Texture Image node work. Do you also need the Window output of the Geometry node as you mentioned here?2020-01-06 at 2:28 pm #22602Yuri Kovelenov
Staff2020-01-13 at 7:46 am #22774Ivan Lyubovnikov
StaffHi GlifTek and Branden,
Object and Window outputs are now supported and will work in the next Verge3D release.
2020-01-13 at 1:51 pm #22779Branden Coker
CustomerThat’s great news! This will be very helpful.
2020-01-13 at 2:30 pm #22784GLiFTeK
CustomerVery cool!!
plz share Discord link & on your signature!2020-03-03 at 7:54 pm #24226Branden Coker
CustomerJust now getting around to try out this feature. Appears to be broken in 3.0.0pre3. Uploading a file here that exhibits the problem. Try to export the glTF and you’ll get a list of errors. Remove the item from the object selection on the texture coordinate node and it will export fine.
2020-03-04 at 6:31 am #24230Yuri Kovelenov
Staff2020-03-04 at 5:14 pm #24296Branden Coker
CustomerOkay, I no longer get errors when exporting glTF with an object in the Texture Input node. Nice work on that fast fix. However, I am not seeing the results I’d expect once the model is in Verge. If I use an empty as the texture object and then animate that empty, the texture should animate with the object. Like so:
Currently the texture does not animate in Verge at all.
Then I tried animating the object (sphere) instead of the empty. The result should be that the sphere moves through the texture. I get this result inside of Verge:
It’s as if there is some delayed movement on the gradient when it shouldn’t move at all in this case.
2020-03-05 at 9:05 am #24351Ivan Lyubovnikov
Staff2020-03-05 at 2:00 pm #24359Branden Coker
CustomerIvan, that’s great. Just tested it here and it’s working as expected with both use cases; sphere in motion and empty in motion. Thanks for the fast attention!
