Object not displaying with sneak peak
Home Forums General Questions Object not displaying with sneak peak
  • #28390
    gr8temi
    Hello. I am trying to view my object in sneak peak but i keep getting a white screen as shown in first uploaded image. Whereas what I have in my blender is what’s in the next image. What am I doing wrong and how to I solve this
    #28411
    May be you need to invert normals.
    #28412
    gr8temi
    I have tried to invert normals. still the same result. By the way I am using BlenderGIS which I believe @yuri has worked on before to generate the map from some shapefiles. Now I need to export the view which the geocam captured which is highlighted in the red dotted lines of the second picture to verge3D but I keep getting a wrong representation of it as shown in the first image uploaded.
    #28414
    lopatam
    Triangulate the mesh.
    Or export obj/fbx and import again, it works?
    Or look at the scale of the mesh and the center of origin.
    #28415
    Please, attach the blend file, so we can look at the problem.
    #28432
    Al Sande
    I just tried an experiment with Blender and BlenderGIS 2.83 and was able to display the generated object in Verge3d sneak peak. However, I did do a couple of things in Blender first.
    1. Rescale the object to be a more reasonable size. It imports with a scale of 1 but the dimensions are huge!
    2. Apply all of the modifiers to the object.
    3. Then, set the scale of the resized object to 1.
    Then click on “Sneak Peak”. I’ve attached a screen grab showing what I ended up with… I did nothing with normals, etc – only the above after running BlenderGIS.
    I hope this helps.
