Home › Forums › Bug Reports and Feature Requests › Object input not working in world material’s texture coordinates
- This topic has 9 replies, 2 voices, and was last updated 3 years, 2 months ago by
kdv.
2023-01-24 at 10:33 pm #59830
sergeverge
ParticipantHello! I am using camera constrained Empty as a source object for world’s hdr texture. It works in Blender, but in exported scene object’s texture coordinates are replaced by default ones.
2023-01-25 at 7:25 am #59839kdv
ParticipantYou don’t have any HDRi texture in your .blend file. And the object’s coordinates are applied to the environment cube texture as expected…
2023-01-25 at 7:42 am #59842sergeverge
ParticipantTexture is not needed really to show setup doesn’t export correctly. This is world coordinates from camera view and expected result which is not preserved in .gltf
2023-01-25 at 7:47 am #59844kdv
ParticipantThat’s what I see after exporting
2023-01-25 at 8:15 am #59847sergeverge
ParticipantHmm, have you changed anything in export settings? I am using verge 4.2 and Blender 3.4.1 and no luck in a couple of browsers.
Could you share export files please?2023-01-25 at 8:23 am #59850kdv
ParticipantNothing special. Just pressed the Sneak Peek button. Blender 2.92/3.2/3.3. Btw, do you expect always to see the same colors on the screen (exactly like on the screenshot) or you just want to texture the the env. cube with the rainbow colors?
2023-01-25 at 8:30 am #59851sergeverge
ParticipantI want hdr texture to follow camera view like you have in blender’s material preview. This is just stripped version of it to pinpoint the issue.
2023-01-25 at 8:35 am #59853kdv
Participantso you want to see the same background image when rotating camera?
2023-01-25 at 8:43 am #59855sergeverge
ParticipantActually, fixed lighting from camera view is what I am after, BG will be a solid color.
Tested your file, thanks. My view is here, something is wrong definitely:Attachments:
2023-01-25 at 8:48 am #59857kdv
then why did you focus on the environment light? Parent a light source to the scene camera. And you can’t change the environment cube’s texture coordinates dynamically…
