No mesh visible after export
Home Forums Graphics / Blender No mesh visible after export
  • #36951
    ddaeng1
    After deleting something accidentally, it did not work, so I deleted the app and recreated it, and then overwritten the existing blender file and exported it, but the mesh is not visible.
    #36952
    ddaeng1
    Solved, I have a question. Do you get an error when setting up LMZA and continuing to export?
    #36956
    You also need to set checkbox in Init puzzle “compressed assets”.
    #36959
    ddaeng1
    After init’compressed asset’, after setting LZMA, there is no problem if you continue exporting?
    #36960
    What do you mean? You want to load partially exported files? It’s not possible, I mean if you use lzma compression you need to enable this checkbox so the engine loads compressed asset. Before gltf file can be loaded exporting must be finished.
    #36963
    ddaeng1
    Export blenders created without LZMA settings. If I export, modify, export, repeat after setting up LZMA, is there any problem? I am a blender beginner.
    #36975
    If you keep all checkbox checked all will be ok.
