- This topic has 11 replies, 7 voices, and was last updated 2 years, 7 months ago by
saranjivac.
2020-07-24 at 7:05 pm #30613
Anonymous
InactiveHallo experts. I need my 3d configurator to retrieve and send data to woocommerce so it effects stock levels. Now I’m pretty sure this might be a simple puzzle setup but please help where you can. Here goes.
In my case the configurator is a watch and each item like the arm bands and seconds and hour arms have their own SKU numbers
1) When the configurator finished loading for the first time I need it to somehow check WooCommerce of every product to see which ones are in stock all SKUs, should an item not be in stock it has to disable(grey out) the selection object for the item.
2) When the watch is configured a checkout button will be clicked and it has to open a second page with all the items listed without showing the SKU numbers(only the names) How can I achieve this? Will it deduct from the Woocommerce stock lists?
3) We have a list of preset Watches on a seperate page. Each preset watch will have a configure option. This has to load up the configurator with a preset configuration. Would I have to save all presets on the server using the Send Data puzzle and hyperlink them using the Load Data puzzle?
I get using Verge3d is easy and awesome and google is my friend. Its just that I’m capped for time at the moment and this has to get going within the next week. Thanks in advance
2020-07-25 at 9:48 am #30629Alexander Kovelenov
StaffHi,
Most things you mention are purely server-side and you better ask about them on specialized WooCommerce resources. When operating with WooCommerce plug-in, Verge3D app simply detects what product (and options) are selected and draws models/materials/animations accordingly. Send Data and Load Data puzzles are used for other purposes, e.g for implementing fully-customized ordering (not with WooCommerce).2020-07-28 at 7:23 pm #30807blackstriker
ParticipantHi,
I need your help on something.
When I add it to the Woocommerce plugin, there is an error in the mobile version. The product is not fully displayed.
How can I solve this problem?2020-07-31 at 8:40 am #30985Yuri Kovelenov
Staff2020-07-31 at 9:15 pm #31028blackstriker
ParticipantYes i am having the same problem.
Please help me.2020-08-02 at 11:57 pm #31049blackstriker
ParticipantHi there,
I’d like to start an e-commerce business which relates jewelry. I analyzed some of related project in this forum, if I find out a solution to make my thoughts real via Verge3D, I’ll get your platform. By the way, I’ll create my website using WordPress and Woocommerce. So, I have some questions at below;
I want my customers to order a product by one-click order method therefore, I need “Add to Cart” function like you did at Spinner example and it should be show the current price simultaneously. However, when I take a look at Spinner product as a look through the eyes of the customer by using mobile site, it gives poor user experience. So my question is; What should I do to increase user experience like your Jewelry Configurator? Should I create my own configurator like your Jewelry Configurator? Because, it is quite good… Can I add “Add to Cart” function at the end of its process? What is your suggestion to me? Where should I start point from? For example; I want to fix 3D image of product all the way top and it shouldn’t move when I scrolling configurator panel. I attached an example about it at below.I want my site format similar with this; http://make.kraishoes.ru/
2020-08-03 at 9:05 am #31058CyberFox
CustomerGood day!
I am very pleased that you liked our work. The KRAI project was developed by our studio.
We have extensive experience in developing such projects. We can consult you or assist you in the development of the project.
We also have extensive experience in integrating 3D configurator into Shopify:
Custom Plywood Desks
Mail: info@cyber-fox.net2020-08-03 at 10:51 pm #31105blackstriker
ParticipantThanks for your interest. However, I prefer to learn how to do it myself instead of taking it effortlessly. :) I just looking for a pathfinder to help me to start my project.
2020-08-04 at 1:34 pm #31147Yuri Kovelenov
StaffHi,
Our WordPress plugin allows to easily integrate simple 3d apps with Woocommerce. Due to its straightforwardness, this solution is not very customizable.
So you’ll have to create your own UI, and probably link it on the server side with Woocommerce in order to use the “Add to Cart” feature.
2020-08-04 at 1:59 pm #31151kubuz
CustomerI want my customers to order a product by one-click order method therefore, I need “Add to Cart” function like you did at Spinner example and it should be show the current price simultaneously.
I was looking at this a while ago.
The closest I got was, adding a plug-in to woo-commerce that could handle custom prices. However, this price needs to be locked in the background.2020-08-05 at 10:14 am #31171blackstriker
ParticipantHi,
So you’ll have to create your own UI, and probably link it on the server side with Woocommerce in order to use the “Add to Cart” feature.Hello again,
Is there a sample site about the features I said?
I think the site I said could not be made before.
I will be very happy if you inform me.2022-09-12 at 12:07 pm #55757saranjivac
CustomerHi, I have a question regarding WooCommerce.
Is there a way to forward the user selection with puzzles without using the woocommerce UI?
So I would like to create my own custom UI, and forward what the user selected to woocommerce so it can determine the price etc.
In the fidget spinner YT video, the ugly dropdown menu from woocommerce was used which I am trying to avoid.
