Need help to make Html based UI and solved puzzles ?
Home Forums Graphics / Blender Need help to make Html based UI and solved puzzles ?
  • #23542
    mashud008
    I watched all the videos in Verge 3D, but I couldn’t find the video anywhere to create a complete HTML based user interface. Anyway, I need help. I have created an HTML based interface, I want ‘Frame object’ to be active when clicking “frame_button” and clicking on any of the above “blue_button / yellow_button” will change the color of the frame. Similarly, clicking the ‘boom button’ will activate the ‘boom object’ and change the color from the top. I can’t do this puzzle. How can I make this puzzle easily?
    :wacko:
    #23557
    colors can be changed with this puzzle
    https://www.soft8soft.com/docs/manual/en/puzzles/Materials.html#materials_set_color
    #23564
    mashud008
    Sir can you understand my problem 🧐 . I want to need, when click left side HTML frame button, it active my frame object and click HTML top of the color set , it changed colors, red, blue, green or other.
    I’m follow your HTML based UI, making two button hide/show. I want make More button and working animation, colors change etc.
    Thank you for your help.
    #23605
    illussimo
    You need to add value nodes in your material setup and then you can access them via the Puzzle Yuri mentioned.
    Check out the Tutorials section on the forum. You can find a lot of helpful information there.
    :bye:
