Home › Forums › Graphics / 3ds Max › Need help, please.
- This topic has 11 replies, 2 voices, and was last updated 3 years, 7 months ago by
NaxosCG.
2021-08-17 at 9:53 am #43688
NaxosCG
CustomerHello again,
I have reached some almost ok shader for my semi transparent plastic boxes, but i get some bad graphics issues (see picture).The object is from Nurbs STEP file, so the polygons are not very good, and we can see that when we move around the object.
Beside full remodel of the objects (very long, and customer will not pay for that, as he provides nice steps files), any idea for the shader ?
Here is the verge test :
https://cdn.soft8soft.com/AROAJSY2GOEHMOFUVPIOE:5c0bd316e1/applications/SundisTest2/SundisTest2.htmlHere is the max file :
https://we.tl/t-MKCWMesHUCAny help would be nice.
You must be logged in to view attached files."1+1=3... for large values of 1"
2021-08-18 at 11:16 am #43718Mikhail Luzyanin
Staffcan you resave file in 2020 vfx or just send a fbx, try also alpha hashed transperency type.
2021-08-18 at 11:28 am #43719NaxosCG
CustomerHere it is :
https://we.tl/t-qdCQ5lbtcYAs you will see i have 3 boxes , one (center one) is the main one, in opaque shader, and looks great in verge3D;
then i have the 2 tests with translucent shaders, in 2 differents mesh import (from nurbs).
As mentionned in my other post, i’m trying to reach this kind of shader (see pictures, please).
thanks.
2021-08-18 at 12:44 pm #43725Mikhail Luzyanin
StaffI’ve made some tests with alpha coverage transp tpe and came with this result. You also need to uncheck gltf 2.0 compatible checkbox. I think this is the best that can be achieved with verge3d.
2021-08-18 at 3:45 pm #43730NaxosCG
CustomerThank you for testing, can you share the file, please ?
Maybe i could duplicate the mesh, set flipped normals and use some whity semi opaque shader, in addition with your test…
2021-08-19 at 8:24 am #43757Mikhail Luzyanin
StaffSorry seems ive deleted it. But the material simple, just set up a transperency (don’t foreget to set thin-wall checkbox) them choose Alpha Coverage in the Verge3D settings of the material.
2021-08-19 at 8:33 am #43758NaxosCG
CustomerSorry, but i don’t find alpha coverage choice.
2021-08-19 at 8:53 am #43762Mikhail Luzyanin
StaffSeems like you have old engine, try to update it to last version.
2021-08-19 at 2:21 pm #43781NaxosCG
Customer3.7.1 with 3dsmax 2022…
2021-08-20 at 9:50 am #43866Mikhail Luzyanin
StaffYou need to wait 3.8 release or use last 3.8 pre.
2021-08-20 at 1:11 pm #43873NaxosCG
Customerok thank you
2021-08-24 at 9:50 am #43953NaxosCG
CustomerYou need to wait 3.8 release or use last 3.8 pre.
I’ve installer pre4 of v3.8 (no production in progress, so i can try beta
And bugs are gone, thank you !"1+1=3... for large values of 1"
