Need help (even paid) – Lights/Ao/Realism
Home Forums General Questions Need help (even paid) – Lights/Ao/Realism
  • #26908
    marshallus
    Hi
    I work on a very small project and i struggle to make it good with lighting, color, AO, shadow.
    The objet look fake, not realistic at all.
    I let you a link to check it, i use a lot of puzzle.
    A link to the configurator :
    https://cdn.soft8soft.com/AROAJSY2GOEHMOFUVPIOE:2a0c412044/applications/test/Index.html
    I need to have shadow, AO, realistic lighting. My project is to add later a wall to stick the model to it.
    Thanks for your help, it’s very low budget project, but every work need to be paid, will did my best !
    #26909
    Xen Wildman
    I see what you mean. Are you currently lighting the object with an hdr image? Some PBR shading will help greatly as well. Will your object be animated? What material is this made of? Textures will help.
    #26927
    marshallus
    Hi
    Thanks for your answer, to begin i’m a confirmed developper and quite newbie with blender.
    I use a JPG for world , i add a value node because i modified it in real time with buttons to make tests.
    I have one sun light with strength of 1 and angle of 11
    I think i use PBR, i use jpg image and bump for normals.
    The project is interactive (add and remove options, change some parts in real time)
    Thanks for your help, if need blend file i could share in private thanks
    Material in real is steel but almost without specular like this :
    https://ibb.co/7RfL1Wp
    or
    https://ibb.co/XYPg1m8
    #26936
    Xen Wildman
    Try this, and click the doors to see in.
    Model needs more detail but you should be able to get a feel for it. Also a different hdr might help.
    https://cdn.soft8soft.com/AROAJSY2GOEHMOFUVPIOE:bb649714bc/applications/Locker_Test/Locker_Test.html
    #26942
    marshallus
    Thanks for your help, animation is already done on the project.
    I will try a new hdr, thanks for tip.
    Anyone from the team of soft8soft could help me, even paid for it?
    #26950
    you could try reaching Verge3D experts listed here https://www.soft8soft.com/digital-agencies-and-freelancers-using-verge3d/
