Musgrave texture + Bump
Home Forums Graphics / Blender Musgrave texture + Bump
  • #57019
    Ayakos
    Hello community, I haven’t found documentation on this yet.
    I found a neat tutorial that makes a water effect on a plane using a mix of texture coordinate + musgrave texture + bump hooked into the normal slot in the principled shader node.
    I exported to Gltf but the effect does not work, am I doing something wrong or are these nodes not supported?
    Thank you
    #57045
    Better to animate normal map across the mesh. Look at the attached example.
