Multi/Sub-Object Materials
Home Forums Graphics / 3ds Max Multi/Sub-Object Materials
  • #4969
    3dmdlb
    Is there a way to use 3ds Max’ Multi/Sub-Object Materials and Object IDs in V3D?
    #4970
    It’s must work without any problems. Have you tried?
    #4976
    3dmdlb
    Good Morning Mikhail,
    sorry for not describe the problem in detail:
    In my exported gltf-scene the Multi/Sub-Object Materials are correct, but i cannot adress them in puzzles.
    In Puzzles all Materials inside the Multi/Sub-Object Material are only available as single Puzzles.
    There is no Puzzle for the Multi/Sub-Object Material itself.
    #4979
    Oh, now I unerstand. Sorry, but there’s no multy/sub-object material for puzzles now, the only way is to divedive youur mesh into sub-objects and place the materials on htem separately.
    #4981
    3dmdlb
    Ok, no problem. Thanks for your reply!
    #44841
    jezuk
    I know this post is old, but I could REALLY use Multi-Sub Object in Puzzles.
    To break up a scene into multiple meshes in order to assign a material isn’t going to work for me because I have hundreds of meshes and just 3 materials in a single Multi/sub-object.
    Please can you guys look at this because Multi-sub object is used very much in 3DS Max.
    Thank you :)
    #55683
    karonte
    me too. it’s a must have feature. or can you please suggest us hot to get a list of materials from a single object?
    regards
    MR
    #64133
    3dcgi
    Hello,
    i did face the same issue today on the watch hands of my latest model.
    They are animated (thanks again to @kdv who helped me get it working) and minute and hour hands include 2 materials
    To get this fixed, I did detach the parts using MatID2 and then i created a dummy for each hand, linking the 2 parts of the minute, and the 2 parts of the hour hands
    Using a dummy will help you to get the materials assigned as required
    Obviously, this isn’t the perfect solution, especially if you have hundreds of meshes, but it is at least a more or less good workaround
    A little helper, for large scenes, is this 3ds script
    Detach by ID
    Using it quite often to split meshes into more manageable parts
    Hope this helps
    Senior CGI Artist @ 3DCGI.Studio #zerophotography
    ➤ Unreal Engine - 3ds max V-Ray
    ➤ Hyper-realistic 3D. Cars, Motorcycles, Products, Archviz Visualizations, 3D & VFX Animations
