Moving a texture around – Not appearing with Verge
Home Forums Graphics / Blender Moving a texture around – Not appearing with Verge
  • #38774
    ocularvr
    Hi, So I am animating a texture UV by adding a modifier to it (UV Project). I add an animated parent to it and all goes as planned in Blender. The animated object moves and the textures move correctly inside Blender. When I run it on Verge, I see the animation of the mesh which is the parent, but the child texture does not move. What am I doing wrong?
    Thanks
    #38839
    Modifiers not supported. Better to do the same with a simple material animation by animation mapping node with value nodes.
    #38900
    ocularvr
    Thank you for that- Ill try it and see – although by reasoning it seems that in order for verge to control any parameter, we need to add a value node. So makes sense.
    Update: Added the node and all is perfect.
    Thanks for the advise
