- This topic has 10 replies, 3 voices, and was last updated 2 years, 2 months ago by
kdv.
2024-07-16 at 9:19 am #75959
studiogijsCustomerI want to organize my code better and notice that I cannot move functions to a different tab, because cutting a function deletes all the calls to it as well. Is there a way around this?
2024-07-16 at 9:28 am #75960kdv
ParticipantIs there a way around this?
In puzzles – no. You can move your procedures in visual_logic.xml. It’s a little complicated task but with the help of Notepad++ it’s much easier…
2024-07-16 at 9:54 am #75964coye
ParticipantMaybe package them into a procedure and then use it in another tab? https://soft8soft.com/docs/manual/en/puzzles/Procedures.html
2024-07-16 at 10:08 am #75967
studiogijsCustomerPackaging them in another procedure doesn’t solve much, you will still need to find the procedure on the page where it resides. And finding stuff in puzzles is one of the weakest parts of it, because it doesn’t scroll to the things you look for.
I’ll try the notepad++ solution, thanks
2024-07-16 at 11:52 am #75972kdv
ParticipantIn puzzles – no.
Correction. There is one simple workaround. Replace all procedure calls this way and they won’t disappear when you move your procedures with Ctrl+X/Ctrl+V to another tab.
2024-07-16 at 12:32 pm #75979
studiogijsCustomerthanks, will do that in future projects. I looked into the notepad++ solution, but that seemed tedious and tricky.
Your solution still means I have to carefully look where the procedures are called.2024-07-16 at 12:38 pm #75980kdv
Participantstill means I have to carefully look where the procedures are called.
Actually, nope.
2024-07-16 at 12:57 pm #75981
studiogijsCustomerwell, not if I do that from the get go, but if I have to replace all calls in my current solution, it still means I have to make sure I replace them all.
2024-07-16 at 1:21 pm #75982kdv
Participanthttps://drive.google.com/file/…/view?usp=sharing
2024-07-16 at 1:41 pm #75983
studiogijsCustomerthanks for sharing the video, in that case moving the function seems quite feasible and faster than replacing the function calls.
But the phrase you quoted refers to the second workaround, not the first.
2024-07-16 at 1:45 pm #75984kdv
ParticipantAgree. The second workaround is mainly for future projects. Replacing all procedure calls could take a lot of time and attention )))
