Move camera freely around object again?
Home Forums Puzzles Move camera freely around object again?
  • #56816
    adgo
    When I run my app in App Manager I can freely move my camera around my object but after I’ve tweened the camera to a new position all I can do is “look around” with the camera fixed in its new position.
    Is there a way to make it so the camera can move freely around my object again after I’ve tweened its position?
    Thanks in advance!
    #56823
    the simplest way is to use two cameras.
    Initial Camera starting at Point A. Secondary Camera closer at Point B.
    Tween Camera from Point A to Point B.
    Once Camera A gets to point B change from Initial Camera to Secondary Camera. (Be sure your Secondary camera is set to orbit).
    #56824
    On my side I see now difference in the camera behavior after four tween camera actions (click Generate PDF).
    https://v3d.net/a6h
    P.S. Looks like in your case the camera position and the orbit target position are at the same point. Then yes, the app camera just looks around like a first person camera (if panning is disabled).
    This object must be an orbit target. Look at it.
    #56833
    adgo
    https://v3d.net/a6h
    Fixed it now! Thanks for your help!
    #56834
    adgo
    Double post
