Mouse zoom wheel
Home Forums Puzzles Mouse zoom wheel
  • This topic has 5 replies, 3 voices, and was last updated 3 years ago by xeon.
  • #47991
    jhill3d
    Can’t seem to locate how to limit the mouse wheel zoom in and out limits. Using 3dsmax I see the camera has parameters but don’t seem to work. Would prefer to use puzzle to control this. Thanks.
    #47998
    What Verge3D version you use? Please try to update to the stable 3.9 release to see if it will work for you.
    X | FB | LinkedIn
    #48005
    jhill3d
    The latest trial version.
    #48034
    jhill3d
    Can you send me a link that shows how to do this please? Can’t locate it in the docs. Thank you.
    #48041
    jhill3d
    Is it possible to disable zoom controlled by the mouse? Set limits on ho much a user can zoom in and out?
    #48045
    The short answer is yes. But the method you use to control it will depend on the camera type you use and the 3D software you use.
    As an example a Camera using Orbit in Blender you have max and min values in Blender to set the distances for zoom. There are also constraint materials that can be used.
    If you could give more detail about your camera, version of V3D, and more about what you are trying to accomplish I could give you a more direct answer.
