Microsoft web server (IIS)
Home Forums General Questions Microsoft web server (IIS)
  • #71894
    visualizer
    Can we run the verge 3d content on Microsoft web server (IIS) ?
    Is there anything else required.
    #71895
    sure you can definitely serve your content via IIS. The only thing, it might require adding gltf MIME type in settings. See this forum topic for more info.
    X | FB | LinkedIn
    #71902
    visualizer
    Thank you Alexander for the hint. I shall try it.
    is it really that simple & straight forward ?
    the error occurring is the content & BG is not loading.
    check the screenshot
    #71904
    Yeap, it’s really that simple. v3d apps work with no problems. just added several missing mime-types
    .gltf application/json
    .hdr image/vnd.radiance
    .json application/json
    .webp image/webp
    .woff application/x-font-woff
    press F12 and see errors.
    #72178
    visualizer
    Ok
    KDV
    I will check this :good:
