Meta Quest3 & above direct publish / deploy feature
Home › Forums › Bug Reports and Feature Requests › Meta Quest3 & above direct publish / deploy feature
  • #80499
    visualizer
    Is Verge any ways going to consider the feature to deploy the set to meta quest3 like headset or similar?
    currently the webversion with PWA works no issues but having a complete deploy set would be an advantage. Since Quest3 is not a direct android compatible and needs a somewhat different settings / config.
    #80500
    It looks like Cordova does not support building WebXR-based apps at the moment, but this might change in the future.
