Messed up scale and orientation of animated objects
Home › Forums › General Questions › Messed up scale and orientation of animated objects
  • #43286
    kevin
    Hello,
    I have a PCB in blender with some components emerging from the board in a nice animation. It plays fine in blender but once exported to gltf or previewed with sneak peak, the animated objects are 100x larger and rotated wrongly.
    The blender file is 70 MB, too big to attach, so here’s a drive link https://drive.google.com/file/d/1_EEDhJRV2hFEmPGMIxntWwB_rOEWXLMm/view?usp=sharing
    Many thanks.
    #43304
    It’s hapens because of delta transfroms that are not supported. If you set them to 1/1/1 in scale you will see the same in blender.
    #43311
    kevin
    Hi Mikhail,
    Thanks for pointing this out to me. I was lucky enough to find this code https://blender.stackexchange.com/questions/145857/how-do-i-apply-delta-transforms-to-normal-transform and convert all the delta transforms to standard transforms, and with a lot of tweaking I managed to get the same animation. However when played in Verge3D all animated objects are moved to the world origin.
    File: https://drive.google.com/file/d/1VrMiUucI5Vuf7wxhNu8kPyfjQWNde5Vx/view?usp=sharing
    I appreciate your time.
    Kevin
    #43320
    You need to set keyframes for all x,y,z for location. If animation exist all not set coordinates will be set to 0 on export.
    #43327
    kevin
    Thanks for the tip, problem fixed. Just one more thing: When opened in Verge3D the animation of my collections ‘first front’, ‘second front’ and ‘third front’ are completely skipped, both in .gltf and .html. I have not restricted the frames in puzzles (https://imgur.com/a/AqoQZIb)
    The same occurs in the viewport when I open puzzles. However very strangely when I let the viewport finish then click ‘run your puzzles’ it starts from the beginning as it should.
    Blender file: https://drive.google.com/file/d/1vI2UL51CmjkQhivxDnle9GJ0OGkVUc-1/view?usp=sharing
    Thanks so much man. Your help is invaluable.
    #43351
    kevin
    Hi Mikhail, I was able to solve this by adding a .1 second delay to the animation in puzzles. I’m happy to say that I’ve finished my product. My supervisor will buy a license. Some things I’d like to mention:
    -Had to turn off autostart and set looping to ‘once’ for every single object, in object properties. This wasn’t so bad since I set up a macro and left it running. If I’m not missing a feature, it would be nice to be able to turn off autostart and looping for all objects in a scene at once.
    -Encountered issue where annotations would drop FPS down to around 3. Turning off ‘fade annotations’ in initialization fixed this completely.
    -Upon creating ‘when clicked’ puzzles, clicking with M1, M2 or middle mouse anywhere to pan or rotate would cause a half-second freeze (lag spike). Work around for me was to turn on ‘double click/tap’ in advanced event options.
    (I’m not using html buttons because webflow embedding is not free).
    You are welcome to point out any potential fps improvements to make, shared folder is entire Verge3D app: https://drive.google.com/drive/folders/138u7_d8L3puA-QAercuSnornbyQU9uA_?usp=sharing
    Thanks for the help. Have a nice weekend :good:
    #43372
    This all happens because amount of object about 4350 – this is extremely huge amount, especially for animated objects. Try to keep them under 100 objects for scene and less that 300-500k amount of polygons (for the whole scene), not the 2.5 million.
    #59260
    qbaismo
    hi Mikhail, does an update exist to this problem with delta transforms? i have to make a decision which framework fits best and delta transform is pretty essential to my work.
    greetings
    #59261
    This feature relies on raycasting and can get very slow for high-poly models. I’d recommend reducing the poly-count down to 100k, which would help to loading time and overall performance as well.
    #59262
    deleted
    #59273
    an alternative to fade annotations. no extra CPU load when the post-processing is enabled and objects have shape keys. and looks the same way )))
    https://v3d.net/a4k
    btw, objects with shape keys (even not morphed) reduce the perfomance most of all when a raycaster is used.
