max_plugin error
Home Forums Graphics / 3ds Max max_plugin error
  • #31168
    teamwhd
    Please help :-)
    #31170
    does this error appear when you perform export?
    #31173
    teamwhd
    It appears when starting max and basically every time I press anything related to verge (sneak peak …..etc)
    #31216
    Looks like you have the wrong path to Verge3D plugin in your system paths:
    Please check it and change to the proper value.
    X | FB | LinkedIn
    #31303
    teamwhd
    I have changed it many times. Hope its not because my name contains Aleš – s with the hook
    #31317
    Can you try installing not into a user folder? Will it work this way?
    #31964
    teamwhd
    I tried but it was not possible to install it somwhere else. The problem is still here and the clock is ticking. I really need to make it running.
    #31966
    teamwhd
    I have tried to put into public folder and now I have another error
    #31974
    Sorry for those troubles. As a possible solution, you might upgrade for for 3ds Max 2021 which does not have problems with encoding.
