Max 2021 …clipping planes…and speding up an animation connected to a slider
Home Forums General Questions Max 2021 …clipping planes…and speding up an animation connected to a slider
  • #44735
    gf3d
    Hi there, i have an issue with verge3d clipping planes in max 2021.
    The settings for the clipping planes doesn´t allow me to pick any object
    to which the clipping plane is applied to…..it doesn´t show any objects in the dropdown list.
    And another question….is there a way to control the speed for an animation by using a slider…to speed up and down the animation?
    I alraedy have a slider and i can connect the speed to it…but not not in such a way that it speeds up and down using the slider.
    Greets
    Ger
    for those who are interested ..i have 2 new interactiv projects
    to look at on my site…..its both work in progress
    https://www.gf3d.de/html/vr.html
    #44741
    You need to add object to Selection set first then choose this selection set in drop down menu of clipping plane.
    I already have a slider and I can connect the speed to it…but not not in such a way that it speeds up and down using the slider.
    You can do it in Advanced settings of Play animation puzzle.
    #44750
    gf3d
    Hi there, thanks for the hint with the selection set….
    the settings in the advanced section of the play animation puzzle don´t help…because i want to control the speed of the animation with a slider i normally use for the playback of an animation…but this time i want to use it for controlling the speed seamlessly…
    Greets
    Ger
