Material performance and optimization
Home › Forums › General Questions › Material performance and optimization
  • #42617
    Hi there,
    I am working on a rather ambitious project with 1000s of objects and equally many materials. I have optimized all the geometry and am at the point of object consolidation/joining and creating texture atlas files to minimize texture count and redraws.
    The question: Is there a performance gain by converting simple materials/shaders into a textures? Or is leaving them alone for Verge3d to calculate better? My guess is that there would be no performance gain converting them to textures and it would just ultimately add issues by adding texture maps and draws. But hoping an expert on here can shed some light.
    thanks in advance.
    #42631
    Hi!
    Generally, it depends on how complex are the materials that you want to optimize. Also, the performance gain can vary on different hardware.
    If the materials are simple as you say, then it’s quite possible that you won’t get any noticeable difference. But on the other hand you have thousands of them, so… the only answer is to test that.
    You can use the v3d performance profiler in your current project to check how much time the materials take to render. You can do that through the puzzle System->print_performance_info or just pasting this into the console: v3d.apps[0].printPerformanceInfo().
    You’ll get various rendering info printed in the console, but the sections that are important in your case are “Materials and Shaders” and “Total Render Time”. If you aim at 60 fps then the total render time shouldn’t be higher than 16ms. Also, if it’s quite low (5-6ms) then there’s probably no point in optimizing at all.
    Also, from “Materials and Shaders” you can see if there are any materials that take much longer time to render than others and therefore are a potential bottleneck.
    Also, you can do this quick test:
    v3d.apps[0].scene.traverse(function(obj) {
        obj.material = new v3d.MeshBasicMaterial({
            color: new v3d.Color(Math.random(), Math.random(), Math.random())
    – this replaces all materials in the scene with the Basic material with no textures (or you can do that only for materials you need to test performance of). If there’s no performance gain even when using Basic, then there won’t be any when using an optimized material with everything baked into a single texture.
    Hope this helps!
    #42650
    Thank you very much. This is great info that can help me isolate issues. I will give it a shot today.
    #42654
    Update:
    Total Render time is 1.6ms
    Total Scene time is killing me at: 2026ms
    So have some optimization still to do but
    the biggest consumer of time are two warnings:
    [Violation] ‘ requestAnimationFrame’ handler took 16149ms
    and
    [Violation]’ reqiestAnimationFrame’ handerl took 7386
    Any way to get rid of these?
    #42743
    Anonymous
    Inactive
    thanks for the awesome information.
    #46823
    orangegoran
    I am also getting similiar problem where where ‘requestAnimationFrame’ takes around 5 seconds.
    [Violation] 'requestAnimationFrame' handler took 4915ms
    This 5 second break is right after loading finishes and before scene is shown.
    Any ideas?
    v3d.apps[0].printPerformanceInfo() prints next values:
    Scene Loading Time: 2107ms
    FPS: 4
    Render Calls: 1626
    Triangles Rendered: 1146454
    Geometry Buffers: 59
    HDR Rendering: no
    Viewport Resolution: 727x1271
    Pixel Ratio: 1 (current) / 1 (device)
    Image-Based Lighting: PMREM 512px
    Lights: 12
    Post-Processing: N/A
    Shadow Map: PCF (Poisson Disk) 12x 1024x1024
    Materials and Shaders:
        System Material - MeshDistanceMaterial - 33ms
         System Material - MeshDistanceMaterial - 2.5ms
         Pergola_roof_material - MeshNodeMaterial - 1.4ms
         StoneFlour - MeshNodeMaterial - 0.8ms
         wall - MeshNodeMaterial - 0.7ms
         System Material - MeshDistanceMaterial - 0.4ms
         PoleMaterial2,PoleMaterial4,PoleMaterial6,PoleMaterial8,PoleMaterial9 - MeshNodeMaterial - 0.4ms
         v3d_default_material - MeshNodeMaterial - 0.4ms
         System Material - MeshDepthMaterial - 0.2ms
         PoleMaterial3,PoleMaterial5 - MeshNodeMaterial - 0.1ms
         System Material - MeshStandardMaterial - 0.1ms
         wire_214229166 - MeshNodeMaterial - 0.1ms
         System Material - MeshDistanceMaterial - 0.1ms
         PoleMaterial7 - MeshNodeMaterial - 0.1ms
    2 x     System Material - MeshDepthMaterial - 0ms
         White Background - MeshNodeMaterial - 0ms
         Verge3D_Environment_World - MeshNodeMaterial - 0ms
         System Material - SphericalGaussianBlur - 0ms
         zip_material_color_P3_P4,zip_material_color_P1_P3,zip_material_color_P2_P4,slide_frame_material.002,slide_frame_material.005,slide_frame_material.006,slide_frame_material.007 - MeshNodeMaterial - 0ms
         PoleMaterial1.001 - MeshNodeMaterial - 0ms
         Pergola.048,Pergola.047,Pergola.046,Pergola.045,Pergola.044,Led.043,Pergola.042,Pergola.041,Pergola_roof_material,Pergola.039,Pergola.038,Pergola.027,Pergola.026,Pergola.025,Pergola.024,Pergola.023,Pergola.022,Pergola.021,Pergola.020,Pergola.019,Pergola.002,Pergola.028,Pergola.029,Pergola.030,Pergola.031,Pergola.032,Pergola.033,Pergola.034,Pergola.035,Pergola.036,Pergola.037,PoleMaterial1.001,PoleMaterial1,PoleMaterial1.003,PoleMaterial1.002,PoleMaterial4.002,PoleMaterial4.003,PoleMaterial4.004,PoleMaterial4.005,PoleMaterial4.006,PoleMaterial4.007,PoleMaterial4.008,PoleMaterial4.009,PoleMaterial4.010,PoleMaterial4.011,PoleMaterial4.012,PoleMaterial4.013,PoleMaterial4.014,PoleMaterial4.015,zip_material_p1_p2_3,zip_material_p1_p2_2,zip_material_p1_p2_1,water_supply_material,power_supply_material,motor_material,Led.026,zip_material_p1_p2_2.001 - MeshNodeMaterial - 0ms
    3 x     PoleMaterial1.001 - MeshNodeMaterial - 0ms
         zip_material_color_P1_P2 - MeshNodeMaterial - 0ms
         wall - MeshNodeMaterial - 0ms
         glass - MeshNodeMaterial - 0ms
         zip_material - MeshNodeMaterial - 0ms
         slide_bar_material.040 - MeshNodeMaterial - 0ms
         slide_bar_material.043 - MeshNodeMaterial - 0ms
         slide_bar_material.044 - MeshNodeMaterial - 0ms
         slide_bar_material.045 - MeshNodeMaterial - 0ms
     Total Render Time: 40.2ms
     Textures & Render Buffers: 15
         Wall texture.jpg - Texture - 1380x863
         kamenje.jpg - Texture - 580x582
    2 x     N/A - Texture - 64x64
         Sun.shadowMap - WebGLRenderTarget - 4096x4096
         Area.002.shadowMap - WebGLRenderTarget - 4096x2048
         Area.003.shadowMap - WebGLRenderTarget - 4096x2048
         Area.004.shadowMap - WebGLRenderTarget - 4096x2048
         Area.005.shadowMap - WebGLRenderTarget - 4096x2048
         Area.006.shadowMap - WebGLRenderTarget - 4096x2048
         Area.007.shadowMap - WebGLRenderTarget - 4096x2048
         PMREM.cubeUv - WebGLRenderTarget - 1536x1536
         N/A - WebGLRenderTarget - 1024x1024
    2 x     N/A - WebGLRenderTarget - 512x512
