Material Params via maxscript
Home Forums Graphics / 3ds Max Material Params via maxscript
  • #51642
    jamjam
    Hey,
    I use the “export to USDZ” puzzle to export my model for iOS.
    The object will not show up unless “gltf 2.0 compatible” is checked in the material params for each material.
    Can we access this settings with maxscript so we can change it easily for each material?
    Also is it possible to add the Material Params to an existing material?
    Thanks and best,
    Gerald
    #51680
    Please use the following script for that:
    for mat in sceneMaterials do (
        if classOf mat == PhysicalMaterial do (
            mat.v3dMaterialData.gltfCompat = true
    To assign material params, you can temporary enable the “Auto-Assign Material Params” option, make some minor tweak with material (such as selection), then disable the option if you don’t need it anymore.
    X | FB | LinkedIn
    #51694
    jamjam
    Thanks, that´s super handy.
