Material flickering
Home Forums Graphics / 3ds Max Material flickering
  • This topic has 1 reply, 2 voices, and was last updated 2 years ago by kdv.
  • #67583
    daim124
    Hi. I’m in the process of creating a configurator and testing Verge3d. I have a problem with Multi/Sub Object Material. I assigned the material to id1 and id2. Id1 is the color that changes and id2 is constant. However, when the camera goes into the garage, id1 appears to penetrate id2. Flickering effect of some sort. Do you know how to fix that. When you pan close enough effect disapears. I’m attaching a link ;) “Type of painting” dropdown. Effect take place with structural plaster
    https://gms-system.com/en/produkt/superstrong/
    #67592
    Z-fighting
    You’ll have to revise you model and remove unneeded surfaces.
