Home › Forums › General Questions › Material essentials for Blender problems
- This topic has 14 replies, 4 voices, and was last updated 2 years, 4 months ago by
vergecurious.
2022-11-28 at 3:57 am #58462
vergecurious
CustomerI must be a complete idjit. Downloaded the material essentials for blender. Extracted the files. Appended a the aluminum object (I tried others) into a standard scene I use. I get zip zero nothing. I then tried to append the aluminum material into a default Verge 3d scene. Zip zero nothing. What am I missing?
Thanks in advance.
2022-11-28 at 1:55 pm #58555Yuri Kovelenov
StaffHi,
Please check out these instructions: https://www.soft8soft.com/docs/manual/en/blender/Material-Library.html
2022-11-28 at 2:58 pm #58557vergecurious
CustomerI’ve reviewed the manual several times. Append, check for missing files and nothing. I can append any of my materials from other files. The materials won’t even apply to the basic Verge cube. I’m not a happy camper at this point:-(
2022-11-29 at 6:58 am #58587Mikhail Luzyanin
StaffHi, we’ve tested the library and it’s ok for us. Can you give us more details how you do or record a video of the process.
2022-11-29 at 7:57 am #58607vergecurious
CustomerYou know honestly this just isn’t worth the hastle. If I can’t append the material, pack the resources and be off, it’s just another problem for me to deal with. I purchased this to make life easier, not harder. I think it’s best if I just get a refund and move on. Please advise how this can be accomplished.
Thank you.
PS I would have sent you a file but is was 5.6 mb zipped. You really can’t do much with 4mb these days.
2022-11-29 at 8:11 am #58608Yuri Kovelenov
Staff2022-11-29 at 8:51 am #58611Mikhail Luzyanin
StaffYou could upload video on youtube aand leave the link here or to any file sharing service and leave the link here. Usually the library make life easier for people and you the first user who ran into this problem. May be it’s combination of software problems. What blender version do you use?
2022-11-29 at 4:49 pm #58635vergecurious
CustomerI appreciate the efforts of the staff. But this was like walking into a swamp. Way more trouble than it’s worth. I built a library of materials within a Verge project that I append from all the time. Maybe that’s why it works and your library does not. I tried your material library because I thought it might be less resource intensive. But it’s not worth all the trouble. I use a Blender clone called bforartists which is simply Blender 3.3.1 with a different ui.
The procedure to append in bforartists is append, apply and if you don’t pack resources automatically, pack resources. In rare cases you have to go to the edit mode and “assign” the material. That’s it. Anything more is just making things more complicated.
Again thanks for your interest.
2022-11-29 at 5:16 pm #58636Mikhail Luzyanin
StaffCan you try vanilla Blender build from the official site with our library? But anyway I’ve tried this bforartist last version and it works fine with our library.
2022-11-29 at 5:51 pm #58639vergecurious
CustomerI’m not sure what you are asking? Are you asking me to use Blender rather than bforartists? If so I’m not up for that at all. What UI are you using in bforartists? It looks nothing like the default UI.
2022-11-30 at 2:40 am #58647vergecurious
CustomerThank you for your prompt refund. It’s nice to deal with people with integrity.
2022-11-30 at 4:43 am #58648FunJoy.Tech
CustomerHi, here is a quick walkthrough of adding the material pack as a custom asset library.
https://drive.google.com/file/d/1tvlFem7tmsgGIpMBqyKdZwNgKjKH1QjM/view?usp=sharing
2022-11-30 at 4:49 am #58649vergecurious
CustomerThe issue wasn’t getting the material to load into blender. They appeared fine in blender. They simply would not export into a gltf file. Zip zero nada was the final result.
2022-11-30 at 5:06 am #58650FunJoy.Tech
It works for me.
2022-11-30 at 5:39 am #58652vergecurious
CustomerWell, I’m glad it works for you. Using a system contrary to the instructions provided by Verge 3d. They kindly gave me a refund so I don’t have to try to play a video recorded at 10x frame by frame. I literally had to go second by second and it still did not work. I’ll stick to my own library where it is append, apply and move on. I was just trying to get materials that were less memory intensive. Lesson learned.
