Material Change Problem: Verge 4.5.0-pre2
Home Forums Bug Reports and Feature Requests Material Change Problem: Verge 4.5.0-pre2
  • #67682
    I’m testing Verge 4.5.0-pre2 right now and found a problem.
    When using the “assign material” puzzle one material will not get assigned correctly. It looks like one solid color with no textures. If i assign that material directly to an object it is shown correctly. So there is no problem with that material.
    I attached my project-folder. I can’t find what is causing this strange behaviour.
    Any help is gladly apprechiated. :good:
    My_Project
    #67683
    Material sources should have exactly the same UV layout (UVMap + Kacheln in your case) as the destination mesh. If this is not the case, it’s possible that after the change is made, materials will be rendered with wrong UVs or no UV at all.
    X | FB | LinkedIn
    #67684
    Material2?
    #67685
    Yep, the black one.
    X | FB | LinkedIn
    #67686
    Thank you very much!! That solved the problem. :good:
    This is very essential to know when using that function with objects that use multiple uv maps.
    #67687
    Indeed! I’m going to extend documentation on “assign material” to make it more clear.
    X | FB | LinkedIn
