Material causing mesh to not load
Home Forums Graphics / Blender Material causing mesh to not load
Viewing 1 post (of 1 total)
  • #51282
    Jonathan Wan
    Hi Mikhail,
    sorry for the late reply on a previous topic (Material causing mesh to not load), I redownloaded the files and tested again, but still ran into the same issue.
    Files:
    https://drive.google.com/drive/folders/1P19hsC3hA_anK3XPBGm_0X6yEFLknWGE?usp=sharing
    The video attached showcases the issue. Console error and video are shown below.
    v3d.WebGLProgram: shader error: 0 35715 false gl.getProgramInfoLog Fragment shader is not compiled.
    v3d.WebGLShader: gl.getShaderInfoLog() fragment
    WARNING: 0:3508: ‘unroll_loop_end’ : unrecognized pragma
    ERROR: 0:6722: ‘node_map_range’ : no matching overloaded function found
    Hope you’d be able to help, thanks! Would also be great if youd be able to attach yopur blender file, I’m afraid my verge3d settings in blender are incorrect.
    Regards,
    Jonathan
