MapControls for Verge3D
Home Forums Programming MapControls for Verge3D
  • #72059
    jakob
    Hello,
    I have a project that includes a 3D model of a real estate project. At the moment I am using Orbit-control. Unfortunately, it does not work perfectly because the Z-axis is not locked.
    I did some research on the internet and came across the “MapControls.js” from three.js. This controller would be perfect for my situation.
    Code: https://threejs.org/docs/#examples/en/controls/MapControls
    Example: https://threejs.org/examples/misc_controls_map.html
    Now my question is whether I can bring the same controller together in Verge3D, or whether I can use this code somehow?
    Thanks for your help!
    Jacob
    • This topic was modified 9 months, 3 weeks ago by jakob.
    #72061
    Within your 3D app….under teh Verge3D settings for the camera there are Target Object/Point controls when using a orbit camera. You have the ability to set the Vertical & Horizontal limits Rotation limits to give you full control to prevent the z-axis rotation or lock your camera to a specific angle.
    You can also do this in puzzles or in code.
    #72062
    jakob
    Hello xeon,
    thank you for your quick reply.
    However, I am specifically concerned with the “panning” and not the rotation. I want the panning to happen only on the horizontal plane (x-axis y-axis) and not also in the z-axis. Just like in the example in my first post.
    I haven’t found anything about this in the settings.
    Do you have any ideas in this regard?
    Thank you!
    #72063
    Here you can find a working solution.
    https://www.soft8soft.com/ru/%D1%84%D0%BE%D1%80%D1%83%D0%BC%D1%8B/%D1%82%D0%BE%D0%BF%D0%B8%D0%BA/%d0%b8%d0%b7%d0%bc%d0%b5%d0%bd%d0%b8%d1%82%d1%8c-%d0%ba%d0%be%d0%bd%d1%82%d1%80%d0%be%d0%bb%d0%bb%d0%b5%d1%80/page/4/#post-19320
