Manual / Material / Opacity
Home Forums Graphics / Maya Manual / Material / Opacity
  • #25123
    fransua
    Hello Yuri
    Two points :
    1/ In the online doc :
    Alpha Mode – select transparency mode: Auto, Opaque, Blend or Mask.
    How can we figure the process for each one ?
    2/ I can’t also get a transparency working for AIStrandardSurface (Transmission parameter not taking into account)
    I am sure I missed a point.
    #25124
    fransua
    Another point :
    3/ When I use the Opacity slider in the Geometry attributes of aiStandardSurface, then Object transparency becomes 0 or 1 after a certain position of the slider (but not fade effect).
    #25128
    fransua
    Point 3/ Resolved. My mistake.
    Actually transparency works with this parameter.
    #25142
    Blend it’s a simple transparency with smooth blending between transparent and opaque parts, mark – is sharp transparency to get sharp edges of the transparent spaces.
    You need to use Opacity instead of transmission, transmission is not supported.
