Manipulate UVs
Home Forums General Questions Manipulate UVs
  • #31079
    johngrigni
    Is there a way to scale the UVs? I have a mesh that changes scale, but I want the uv’s to stay the same (shower enclosure scaling to user input, but the ’tiles’ remaining square). Can I do this? Do I set up a projected uv in blender?
    #31081
    origgin
    I also tried this last week but I did not manage to do it.
    Setup
    This setup worked well in blender using shape keys but unfortunately not in Verge3D (looks like a kind of bug or limitation for me). The object does not change when I manipulate the shape keys values.
    Maybe you can try to explore further in this direction or find another solution (what I did).
    #31082
    You need to connect a value node and change it. Like this.
    You can animate it or use Set Value puzzle to change.
    #31085
    johngrigni
    Thank you!
