Make an App to start the Meta Quest 3 Browser with the project URL
Home Forums Tutorials Make an App to start the Meta Quest 3 Browser with the project URL
  • #79464
    tomtm
    Since it’s not possible to define a custom start screen in the Meta Quest Browser and access to a URL is only available via bookmarks, I want to briefly show you how to create a simple app that merely loads the browser with your desired URL.
    The app’s shortcut can then be neatly placed in the taskbar for easy access.
    To create the app, I used the online tool Kodular:
    https://www.kodular.io/
    The great thing about Kodular is that it works similarly to Puzzles, with the building blocks called “Blocks” instead. Kodular is very user-friendly, and exporting the app as a .apk file works seamlessly.
    Once you have your .apk file, you can install it on your VR headset using SideQuest.
    Attached is a screenshot of the Blocks needed to call the browser and close the app shortly afterward.
    #79650
    visualizer
    Hey
    tomtm
    I saw this post a bit late but what you shared above really a nice thing & interesting.
    I am also working on Quest3 for some time now.
    Some times next week I will check this thing.
    Thank you for sharing :good:
    #80027
    tomtm
    Did it work for you?
    I am very happy to have some icons for the project in the task bar, it’s much easier for clients.
    #80393
    visualizer
    Hye
    sorry for delayed reply
    I havent yet tested it .
    will check n update back
