- This topic has 13 replies, 3 voices, and was last updated 1 year, 4 months ago by
bigmike814.
2023-11-07 at 9:17 pm #68267
bigmike814
Customerhello,
I’m testing the boolean feature and am out of ideas on how I can get it to update/cut both items (or more) when I move an item. Don’t even know if this is possible.
Seems like the objects would need to be joined in order to make it work as is.
Anyone have any ideas?
2023-11-07 at 9:45 pm #68269kdv
ParticipantFor now, as it is, you can subtract only one mesh per step. Groups and lists are not supported. If you need two holes you’ll have to join those two meshes.
2023-11-07 at 9:49 pm #68270bigmike814
Customerthat’s what I thought. Do you know if there’s a way to add clipping planes in a way that can get the same effect?
2023-11-07 at 9:53 pm #68271kdv
ParticipantFour clipping planes to cut a square hole? Have no idea
2023-11-07 at 10:37 pm #68272bigmike814
CustomerI figured. Ask me how I know. lol
2023-11-07 at 11:46 pm #68273kdv
ParticipantGood. CSG not needed )))
2023-11-08 at 2:33 am #68274bigmike814
Customerhere’s a test I did. Still trying to figure out the coordinate system, but it can be done.
2023-11-08 at 4:46 am #68275bigmike814
Customerwell, I got one working but when I add another clipping plane hole, they both go away. I’ve seen configurators do it, so I know it’s possible, but don’t know if that is some three.js wizard writing their own code or not, but I might have to move on from this idea.
Here is the latest test:
2023-11-08 at 5:11 am #68276xeon
CustomerWith booleans being new this is an interesting thread but I was wondering what the real-world problem is that you are trying to solve with booleans? Maybe its not a real-world problem and thats fine too. Just curious. I have not come up with a business need for booleans yet but I am interested to see what others are thinking.
Tutorials - https://www.xeons3dlab.com2023-11-08 at 2:40 pm #68293kdv
Participantbut when I add another clipping plane hole
that’s a dead end direction. As a workaround you may use cloning and geometriy batching to make several holes in one step. one important thing: to be merged objects should have the same material.
In general, it’s needed for creating holes in parametric models (windows/doors in garage-type configurators or holes for wires in table tops). And for now this new puzzle can’t provide the required functionality
2023-11-09 at 12:20 am #68302bigmike814
CustomerI’m building a shed/garage configurator and want to hide the inside framing so I don’t have a stud going through the window.
Sometimes I’d need to hide the door and maybe even a couple windows. Which is why I’d need more than one boolean per mesh.
I’m going to use physics and hide anything touching. And add additional studs per item added.
2023-11-09 at 12:27 am #68303bigmike814
CustomerAs a workaround you may use cloning and geometriy batching to make several holes in one step.
I guess I could use the same material on the edges. Would that separate out the similar material and leave the transparent material?
I’m just curious at this point.
2023-11-09 at 12:30 am #68304kdv
ParticipantGeometry batching works as follows: all selected meshes with the same material are merged into one mesh (providing one render call). If you try to merge a window and a door having different materials you’ll fail.
Or just wait a little. Maybe they’ll fix the issue before the release.
2023-11-12 at 6:40 am #68432bigmike814
Customergot it figured out. Just a matter of cutting the first hole, then save that mesh to run the next loop of the item being cut and reassigning the material.
