Home › Forums › Graphics / Blender › Localhost refused to Connect with Chrome 83.0.4103.61 on macOS High Sierra
- This topic has 36 replies, 5 voices, and was last updated 4 years, 5 months ago by
Yuri Kovelenov.
2020-07-30 at 3:30 pm #30935
Holt_Interactive
CustomerYeah, I must have done something unintentional. I reDL’d 3.3 and tried again with no issue in regards to add-on activation. Attached is the output from Terminal after that process. I am still getting the Localhost error in the browser, but this output is definitely different than before.
2020-07-31 at 7:56 am #30981Alexander Kovelenov
Staff2020-07-31 at 12:41 pm #30998Holt_Interactive
CustomerYes, it’s there, and I’ve got over 1Tb of free space (see attached screenshot).
I’m running a retrofitted Mac Pro tower with High Sierra, 12-core Intel Xeon, 64 Gb of DDR3, with an NVidia GTX 980 Ti.
2020-07-31 at 3:44 pm #31015Alexander Kovelenov
StaffI’ve found a strange file path in your error message:
/Users/USER/Library/Application Support/Blender/2.83/scripts/addons/server.py
Can you please send us contents of your Blender addons directory:
2020-08-03 at 6:04 pm #31096Holt_Interactive
CustomerThis is a strange file path. I went looking for it, and I cannot find that directory. There isn’t a Library folder in my USER folder. I searched for invisible files and it did not show up, under any term used in the folder names of that file path.
2020-08-04 at 7:06 am #31117Alexander Kovelenov
Staff2020-08-04 at 5:55 pm #31159Holt_Interactive
CustomerAh! Those tricky tricksters; you’ve got to hold down the alt key as well.
Alright, here’s a screenshot of those contents.
2020-08-07 at 10:57 am #31258Ivan Lyubovnikov
StaffI guess that’s the cause of the previous errors. Try to remove or rename that file
and run Blender from the terminal. The message “Address already in use, exiting” can still appear, though.Co-founder and lead developer at Soft8Soft.
2020-08-07 at 3:28 pm #31271Holt_Interactive
CustomerI moved server.py outside of the addons folder and ran Blender from Terminal. The output is attached. Thank you for your continued assistance.
2020-08-07 at 4:01 pm #31274Ivan Lyubovnikov
StaffOK, as I thought those errors are gone, but “Address already in use, exiting” is still there. So, if you tell me what version of Verge3D you are currently using I can post a modified version of
server.py
, which should output more detailed information about the actual cause of that message, if you replace theverge3d/manager/server.py
file with it.Co-founder and lead developer at Soft8Soft.
2020-08-07 at 4:10 pm #31275Holt_Interactive
CustomerCool, thanks Ivan. I’m running 3.3.0 as of June 30th.
2020-08-07 at 4:22 pm #31276Ivan Lyubovnikov
StaffHere’s the archive with the modified server.py file: server.zip. Just replace the file
manager/server.py
in your verge3d distribution with it and try to run Blender again. This time the console output should be more informative.Attachments:
You must be logged in to view attached files.Co-founder and lead developer at Soft8Soft.
2020-08-07 at 5:29 pm #31279Holt_Interactive
CustomerOkay, just replaced that python script, and here’s the attached output.
2020-08-10 at 10:31 am #31309Ivan Lyubovnikov
StaffHmm, it seems that something is wrong with the network configuration on your machine, for example, if the
/etc/hosts
file doesn’t contain an entry for localhost. Can you show the contents of/etc/hosts
?Co-founder and lead developer at Soft8Soft.
2020-08-10 at 12:49 pm #31320Holt_Interactive
CustomerI used Go to: /private/etc/hosts and here’s a screenshot of what’s inside /etc/ but (un)surprisingly, there isn’t a host folder located there.
