- This topic has 10 replies, 3 voices, and was last updated 5 years, 11 months ago by
Yuri Kovelenov.
2019-03-07 at 9:18 am #12265
Retailleaum
CustomerHello,
I use Verge3D as a professional tool and I created a set of Verge3D pages with one serving as a starting menu sending the user towards the others. Does that work well with your network ? I would like to recreate this pages for a local use, without them being connected to the internet, but I’m not quite sure how to do it. Is it even possible ?
Best regards
2019-03-07 at 10:13 am #12273Yuri Kovelenov
StaffHi,
The content created with Verge3D is required to be served through a website. Verge3D Network suits this purpose well. You can use your own server instead, for example, a WordPress-powered one for which the Verge3D plugin is available.
You can of course run Verge3D apps locally without Internet connection, using a local webserver, or through the App Manager.
2019-03-07 at 10:40 am #12276Retailleaum
CustomerThe way I’m trying to set things up is as followed : I would like my main menu to point towards a .html page that would be stored locally, but I’m not quite sure of what to assemble in the puzzle interface. I tried using an “open web page” node and a “call JS function”, both unsuccessfully. I’m afraid I’m not versed enough in scripting and/or using the puzzle interface. Can you see what I’m doing wrong ? I have attached a screenshot, hoping it will help you pin point the problem.
Thanks for your assistance,
2019-03-07 at 1:04 pm #12284Yuri Kovelenov
Staff2019-03-07 at 2:00 pm #12286Retailleaum
CustomerThank you for your answer. I think i did it but i can’t open the first file in my tablet ( i try the HTML and it don’t open)
2019-03-07 at 2:05 pm #12287Yuri Kovelenov
StaffYep, it will only work on the same machine. For running from a mobile device you can use one of the following methods https://www.soft8soft.com/docs/manual/en/introduction/Testing-Mobile-Browsers.html
2019-03-07 at 2:59 pm #12288Retailleaum
CustomerThe problem is, this is a project I am doing for a client that won’t be able to connect to my local network. If I understand correctly, the methods listed on the link you shared would be linking our mobile device to the informations on my computer. Is that it ?
Thanks again for taking the time to try and help !
2019-03-07 at 3:08 pm #12289Yuri Kovelenov
Staff2019-03-08 at 9:34 am #12346Retailleaum
CustomerHi,
I find a way! I copie all the files in my tablet and I telecharge an HTML viewer ( Local HTML Viewer) in Play Store and it works!!
Thanck you for your time2019-05-30 at 7:23 am #15088p413xp413
ParticipantHi Yuri,
Can I use my own CDN, even after the subscription period ends?Niruban | P413
Artist. Always Learning.
Used to be an accountant.2019-05-30 at 7:35 am #15089Yuri Kovelenov
StaffCan I use my own CDN, even after the subscription period ends?
Sure! The Verge3D license is perpetual. The maintenance subscription only covers software updates and the use of Verge3D Network.
