loading scene error
Home Forums Programming loading scene error
  • #15858
    Anonymous
    Inactive
    Hello,
    I try to figure out how to load the scene into existing scene. I use example code link
    additional I use puzzle setting to load the scene. I would like to replace sphere object there with my own object.gltf.
    Doing this the scene is not loading and I get following error code in browser:
    `[.WebGL-0x2f7bc8180e00]GL ERROR :GL_INVALID_OPERATION : glDrawElements: attempt to access out of range vertices in attribute 0
    So my questions:
    – how to implement the own scene in that example code
    – how to figure out the position of the loading object in that scene
    I provide also my project file.
    #15875
    Hello,
    that example is hand-coded with JavaScript and must be adjusted / reworked first for using with the Standard project template and Puzzles. See more info here https://www.soft8soft.com/docs/manual/en/introduction/Using-JavaScript.html
