load scrollable DIV onto screen with text and images from html menu
Home › Forums › Puzzles › load scrollable DIV onto screen with text and images from html menu
  • #34861
    jaspixel
    I have scoured the searches, but am still scratching my head, so would appreciate a bit of help please.
    I have set up a menu with various buttons that action animation functions well. I just need to finally make one of the html menu buttons load a window/popup with a fixed position and size, and make it scrollable as I want to load text and images into it (perhaps from a separate html file using load data).
    I need this to be a responsive floating window with text and images that will adjust to different screen sizes. Am I better off creating a DIV via puzzles and loading it for example to an empty object set in the 3D model, or is it better to have a floating window in a DIV and loading also created via the puzzles please?
    I couldn’t find an example that showed how to create a floating div window with text and images using puzzles that appears after clicking on an html menu. If you know a link that show this please share.
    Many thanks,
    Jas
    :bye:
    #34952
    you could employ some web builder tool such as Webflow to create advanced and mobile-friendly UI. You can check out some videos on using Webflow and Verge3D on our YT channel.
