- This topic has 6 replies, 3 voices, and was last updated 3 years, 8 months ago by
AVerge3Der.
2021-06-08 at 6:36 pm #41940
rollos5son
ParticipantHi all!
I’ve been tinkering with Puzzles for some time with little difficulty and much enjoyment but I’ve finally run into a challenge.
What I’m trying to do is simulate the loading and saving of a set of objects for eventual hookup to a database (as project files). As part of this testing process I store my List of objects in a Dictionary on “save”, then attempt to load the contents of the Dictionary entry back to the List on “load”.
My problem is that when I do this, rather than replacing the contents of the List array variable, the loaded Dictionary content is appended, so that when I do my test load I get multiple iterations of the set of objects. Worse, some of my attempts to clear the List variable first make it impossible to load the contents of the Dictionary list at all.
If necessary I can provide an example app.
2021-06-08 at 10:21 pm #41948GLiFTeK
CustomerHi,
Before you save to your list, define it as an empty list using the “create empty list”Then do your adding of values to it, then set it as the value ofyour dictionary key.
plz share Discord link & on your signature!2021-06-08 at 10:28 pm #41949rollos5son
ParticipantThanks for the tip!
I’m feeling a bit foolish now because I went back over my code more thoroughly and found the problem:
I’d set up a function within a loop to assign new names to the reloaded objects, but I was then adding the new names to the same list!
I solved the problem by assigning those names to a second list which I could then copy back into the first after finishing up the renaming. Everything is working perfectly now!
For any relative newb like me, let this post be a helpful lesson – proofread, proofread, proofread!
2021-06-09 at 2:09 am #41951GLiFTeK
CustomerOh it happens heh.
I’ve seen my share of facepalms.
I have a plugin you may be interested in I’ll be releasing soon for saving to offline storage that may help in your project.
plz share Discord link & on your signature!2021-06-09 at 3:25 am #41952rollos5son
ParticipantTrue, yet I’m also coming to appreciate more and more that mistakes truly are a great teacher. I’ve had to learn coding on the fly and the behavior of functions still makes my head hurt, but I’m getting more used to that.
Thanks for the heads-up on the plugin!
2021-06-09 at 4:35 am #41954GLiFTeK
CustomerTrue, yet I’m also coming to appreciate more and more that mistakes truly are a great teacher. I’ve had to learn coding on the fly and the behavior of functions still makes my head hurt, but I’m getting more used to that.
Join the Verge 3D Discord server chat if you like.
Contact me there for info and help!Visit the GLIFTEK Verge3D Plugins Store!
plz share Discord link & on your signature!2021-08-02 at 1:20 am #43362AVerge3Der
ParticipantThis sounds interesting to me as well, the plugin. If this can work with SQLite that would be a plus.
