List Comparison
Home Forums Puzzles List Comparison
  • #25359
    sirhc
    Hi :bye: ,
    When I compare a list of variables to another list,….it always returns false??
    Even in the console (F12) the lists are the same??
    Keeps returning false?
    It feels I’m doing something wrong.
    Anyone care to take a look?
    https://cdn.soft8soft.com/AROAJSY2GOEHMOFUVPIOE:137c2c3806/applications/my_awesome_snapp7/my_awesome_snapp.html
    I think the solution might be simple,….
    thanks in advance :good:
    Chris
    Technical Artwork Specialist@TBL.nl
    #25363
    In JavaScript (which Puzzles are based on), comparison of an Array with another Array always produces false, because unlike with Numbers, this operation just checks if 2 Arrays are different instances or not.
    The simplest workaround is to convert your list to text first (aka “join” operation), and then compare the text lines.
    https://www.soft8soft.com/docs/manual/en/puzzles/Lists.html#list_text_conversion
    #25364
    sirhc
    I going to try that!!! :good:
    Tnx for the quick reply Yuri!!!!!
    much appreciated!!!!!
    #25380
    sirhc
    Hi Yuri,
    thanks for the help about the ‘list’ issue.
    It’s been fixed!; as you said with the convert to text option.
    Brings me to the next question:
    Why is my project(link in first post) so blurry in Microsoft Edge.
    (and what I hear also in Opera (have not been able to check that))
    I’ve been googling,…..can’t find much,….
    Found something about edge using GPU rendering or something :wacko:
    I don’t know :scratch:
    Is there a way to fix this??
    Please help,…..(again) :-(
    Chris
    #25388
    glad it worked for you!
    Are you using the latest version of Microsoft Edge browser?
    #25390
    sirhc
    Yes , that helped!!
    Issue Solved!!!
    Tnx Yuri, U R the best! :good:
    #25432
    sure! :good:
