linear rotation intopolation
Home Forums Graphics / Blender linear rotation intopolation
  • #63974
    Anjanita
    Linear rotation interpolation with multiple key frames works perfectly in Blender but just rotates in a random fashion when exported to verge. This used to be fine but seems an issue since I upgraded to 4.3
    #63978
    with four keyframes (0°, 120°, 240° and 360°) it works quite good
    https://v3d.net/iqo
    in 3.x.x it used to work with just two keyframes.
    #63979
    Anjanita
    Ah ok Thank you, it actually rotates 7 times whilst moving downwards (think of a screw being installed) so is a bit of a pain to add in all the extra keys but ill take a look
    #63981
    your animation is almost ready. just move the slider to intermediate frames, point to the rotation field and hit i key. you don’t even need to type in numeric values for those frames.
    #64012
    Anjanita
    Yes your right, that worked a treat, thank you.
    On the subject of bugs since upgrade I am also having a problem where a button on the UI changes the material colour using puzzles. The material colour is referenced from a csv as a hex with roughness and metallicity values but its no longer working. I didn’t write the puzzles and the chap who did is no longer with us so im not sure where the issue is.
    I will post as a separate subject but you really seem to know your stuff so thought id try you first :)
    #64015
    Anjanita
    Scrap that, its working now, I’m not sure what was wrong and if it was my mistake (probably) but i’m back on track!
