Limit the drag area
Home Forums General Questions Limit the drag area
  • #45046
    Walter
    Is there a way to limit the dragging area? For example, if drag/move around the object I don’t want see the bottom of my model, or pan the model “out of the screen”. We have try many things and we found no way :cry:
    We are using 3ds Max
    #45051
    If you are referring to limiting the orbit rotation…you can set rotation limits in the camera Verge 3d Settings. You will have both veritical and horizontal rotational limits you can specify.
    If you are dragging the object…you can use rotational constraints.
