Learn Verge
Home Forums General Questions Learn Verge
  • #55902
    lucca
    I’ve made a light simulation animation, that is, when the key is turned on, the light is on. but after i run it, the light animation is not detected. how to show light animation in 3d verge. thank you
    #55905
    You need to do the same with the puzzles logic instead of internal Blender instruments.
    #55910
    lucca
    thanks for the answer, permission to ask again, i blender I have animated the button using emission with blom and connected it to the light area. which puzzle do i use to call that animation in 3D verge
    #55913
    Play animation puzzle. Watch this tutorial series it can help to understand basics.
    #55932
    You should add the Value node to the Emission strength input and animate its value to make it work in Verge3D.
    https://www.soft8soft.com/topic/how-to-make-emission-light-blinking/
