Keyboard control
Home Forums General Questions Keyboard control
  • #33079
    vivektrivedi478
    hi I created a simple onclick event, which worked perfectly, how do i do the same thing by pressing “ESC KEY” or any other keyboard key?
    #33087
    you can use keyup event for this purpose. There is an example setup in the Puzzles library called “Keyboard Controls”.
    you can find the table with key values here:
    https://developer.mozilla.org/en-US/docs/Web/API/KeyboardEvent/key/Key_Values
    #33093
    vivektrivedi478
    thank you :good: :good:
    #76042
    Anonymous
    Inactive
    As far as I know, you can run any such event on pressing “ESC KEY” using the keyup event in your code. You shall have to register a listener for keyup events and then you can check which key was pressed.
    If you’re interested in even more keyboard customization options, check out the qwertybro.com. They have various keyboards and accessories that might help you get that perfect setup.
    • This reply was modified 7 months, 1 week ago by .
