js programming capabilities vs puzzle capabilities
Home Forums Programming js programming capabilities vs puzzle capabilities
  • #25190
    thomasup
    a short question about programming:
    – are all features aviable to puzzles also aviable in code?
    – if so, is there a documentation on the function calls/names/usage, similar to the puzzles doc?
    #25200
    Yep. The Puzzles are translated to JavaScript. You can check out the generated code by opening the human-readable visual_logic.js found in your app folder.
    Here is the API reference.
    #25206
    thomasup
    oh nice! that is very good to know. thank you
    #25207
    #25234
    thomasup
    nice. all those script references!
    looking at the teapot heater example logic helped me a lot. makes me confident that i will will find all needed features, and this engine would be viable.
    p.e. app.controls.tween does not appear in the documentation. also takes a mysterious 4th argument “doSlot”, which is mostly an empty function.
    but it is usable as is, so not really a problem.
    #25258
    sorry for that, we’ll double check the reference
