It would be great to animate UVW Map
Home Forums Bug Reports and Feature Requests It would be great to animate UVW Map
  • #6448
    NicolaeIonascu
    Hi!
    This would allow to “dissolve” objects during animation using for example a gradient map on opacity. Or any other animated mask. It looks spectacular.
    And what about the animation of the visibility?
    Thanks
    #6494
    Hi!
    To do so simply animate transparency for your materials. You can use the following material setup as an example:
    X | FB | LinkedIn
