It seems that I can only animate movements
Home Forums General Questions It seems that I can only animate movements
  • #81126
    Cesar Morales
    Hello, I have been using Verge for some time, even thought not for a lot of things, but it seems that only thing i can successfully animate are rotations, movements, etc, but i cant animate geometry changes, material changes,etc… specially because i want to animate those things with the scroll down and is not possible, does it happen to someone else?
    #81133
    qiangge
    ColorAnima base Cnoise
    colorAnima2 base Snoise
    Coincidentally, I have recently tried using shader material for animation plugins. Welcome to take a look
    • This reply was modified 3 days, 7 hours ago by qiangge.
    #81140
    Geometry changes- use shape keys/morph targets.
    Materials you can use the Value node and animate textures.
    Are you stating you can’t make either method work on scroll down? What version of V3D and 3D app are you using?
