is this normal or should i delete one ?
Home Forums General Questions is this normal or should i delete one ?
  • #24452
    Draco080
    if so which one should be deleted?
    #24470
    illussimo
    When you switched to a new V3D version you have to restart Blender. Then it will be resolved automatically. :yes:
    #24479
    In the latest Verge3D versions, setting Scripts path manually is no longer required. Instead, the installer copies Verge3D addon to Blender’s installation folder. So the first line is ok, and the second line hints that you have Scripts path filled in the Blender preferences. Just clean it up.
